Guest dgb03obw Posted July 18, 2003 Share Posted July 18, 2003 Are the current MT 2003 Outbacks dual mode? I tried to find some info but it's all very top level. What exacty is it....lower ratios with lower RPMs? Many Austrailia sites mention it and one web site said that it is "easy to use". How would a different mode be chosen? Thanks in advance, Dean 03 OBW Limited 84 GL wagon 1.8t...totaled in 89 :-( Quote Link to comment Share on other sites More sharing options...
Guest ShawnW Posted July 18, 2003 Share Posted July 18, 2003 Sounds like a dual range ft 4wd trans like our late 80's RX models had. Quote Link to comment Share on other sites More sharing options...
Guest jcdenton Posted July 20, 2003 Share Posted July 20, 2003 dual mode is probabaly austrailian for dual range. it could be a push button or lever ingagement, it lowers the gears for more power for off-road and places that need alot of traction (snowy mountain-pass driveways and stuff like that.) Quote Link to comment Share on other sites More sharing options...
Guest wrxsubaru Posted July 21, 2003 Share Posted July 21, 2003 The dual range I am pretty sure is levar activated, and is only avalible on manual transmisions and is not avalible in the US. It gives you lower gear ratios so you have some more power, and can drive easyier at slower speeds when going off road. Quote Link to comment Share on other sites More sharing options...
Guest camosuba Posted July 22, 2003 Share Posted July 22, 2003 Dual Range is dual range here in Australia as well, and yes they are manual gearboxes with a seperate lever to change up and down much like another gear, I'm fairly certain it is standard fitment on amnual models except for the turbo editions which are single range manual or auto only. The low range is handy for climbing hills or creeping in trafffic and for the early Liberty/Legacy models the lower gearing from the earlier L series dual range gearboxes does swap in and give much better reduction gearing as wrxsubaru says <img border=0 src="http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif" /> Quote Link to comment Share on other sites More sharing options...
