burning oil smell
5 replies to this topic
#1 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 26 July 2013 - 07:38 PM
recently done  weber swap now i smell burning oil from time to time
#2 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 26 July 2013 - 07:58 PM
What did you do regarding the PCV system?
#3 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 27 July 2013 - 02:09 PM
i ran the drivers side crank case hose to the pcv valve
#4 djellum
djellum
    Eat, Live, Breath Subaru
  • 797 posts
  • Vancouver WA
Posted 27 July 2013 - 02:39 PM
do you have a breather cap on the passenger side?  you need to take air in on the passenger side.
if you just have a hose going directly to the pcv then its probably sucking up oil like a straw.  you should put a T inline with a small opening to allow some fresh air in.  you want to keep the air inlet small so you still suck crank case gasses, you can run it to the air cleaner which would be best.
also dont forget when you pull a bunch of stuff off you get oil and grease spread around, it might just need a good washing.
#5 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 27 July 2013 - 03:08 PM
If any part of the PCV system vents to the atmosphere, you are likely to get nasty oil smells.
Or, as was pointed out, it could just be burn-off from parts that got oil on them.
#6 Lacyjs9
Lacyjs9
    USMB is life!
  • 138 posts
  • Mcleansville NC
Posted 27 July 2013 - 06:26 PM
my passenger side is ran to the air breather so i should "T" it off at the pcv valve and run it into my air breather?
