Guest todds Posted August 10, 2003 Share Posted August 10, 2003 is it a easy fix to correct.? my wifes started over charging today. i've just swaped with used , now have 6 that over charge. easy fix?? todd Quote Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted August 10, 2003 Share Posted August 10, 2003 First I assume you mean that the volt gage is reading in the red portion of the scale. The problem is that the voltage regulator is not working anymore. Now how to fix this problem depends on what year yours is. But first check the voltage across the battery using a test meter it should be between 12.5 and 14 volts, remember to test while the engine is running around 2500 rpm because at idle you can still get normal reading even if the regulator is bad. If your readings are like 15 or more then it's the regulator. If it's an 80 or 81 it has an external voltage regulator and you just need to replace it. If you have an 83 it has an internal voltage regulator that's inside the alternator. I belive you can open up the alternator and replace the regulator but most people simply go and get a rebuilt alternator from a parts store or they find a good used one. For 82, I can't remember if it had an internal or external regulator. Quote Link to comment Share on other sites More sharing options...
Guest edrach Posted August 10, 2003 Share Posted August 10, 2003 Craig is right on the money. Do it soon since the overvoltage can harm other electronics in the car--some expensive (ECU) and some not so expensive (headlights). Quote Link to comment Share on other sites More sharing options...
Guest Skip Posted August 10, 2003 Share Posted August 10, 2003 another check mark beside Craigs answer and you better believe what Ed says it can also cook your battery in short (operative word) order. I have changed internal VR's, it takes heat sinks and a good solder touch. I swapped them from alts with other problems (blown main diodes) I like Craig's idea of getting a rebuilt or just another alt from a bone yard. Quote Link to comment Share on other sites More sharing options...
Guest todds Posted August 11, 2003 Share Posted August 11, 2003 my alt. is/was putting out 17,18 volts .we ran it back from folks place with heater fan on full ,lights on and kept it under control. i just put in a used one today. now i got 7 over chargers. napa wanted $90. i'm going to price the inturnel regulater. and mabey fix one for next time. thanks todd Quote Link to comment Share on other sites More sharing options...
Guest Flowmastered87GL Posted August 11, 2003 Share Posted August 11, 2003 If it helps I think the voltage regulator on my brat is in the alternator as it takes the exact same alt as my 87 GL For some reason though, my voltmeter runs at 12 volts ALL the time even though the autozone diagnostic machine showed 13.6 or something... <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\"> The gas guage is sometimes kinda slow to "wake up" when the brat has sat afew days too (takes like 5 blocks) Maybe its time to yank the cluster and clean it up. Quote Link to comment Share on other sites More sharing options...
Guest Hondasucks Posted August 11, 2003 Share Posted August 11, 2003 82 uses an internally regulated alternator, my 82 sedan's got one in it. I'd get that shiznit replaced before you cook your battery, you might want to have it checked too (overcharging will boil the water out of it) Quote Link to comment Share on other sites More sharing options...
