8 replies to this topic
#1 Guest_baccaruda_*
  • Guests
Posted 10 August 2003 - 12:08 AM
rrgh. sunroof won't open.. it slides about a half inch and stops, motor still going. I've even changed the motor with a known good one. does the same thing. I doubt it's electrical as I can't assist the motor by pushing the glass. it feels like it's stuck.
Can I reach whatever is the likely cause to fix this if I just unbolt the glass? Or am I pulling my headliner to fix this? don't really want to..
I have a couple projects to get ready for if I am, though :D
#2 Guest_rXSNRG_*
  • Guests
Posted 10 August 2003 - 12:15 AM
Andy, mine did that for awhile and if i pushed up gently while opening it would work.
#3 Guest_jcdenton_*
  • Guests
if you pull the headliner down it would help you put in a xt maplight!<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/grin.gif ALT=" >D">
<a href="http://www.subaru4wd.net/" target="top">xt maplight install info</a>
#4 Guest_calebz_*
  • Guests
you could start by taking the glass out and having a look around.. only takes about ten minutes to get the glass out.
Might just need lubrication
#5 Guest_Flowmastered87GL_*
  • Guests
Posted 10 August 2003 - 12:19 AM
hmmm did you change the GLASS or the entire assembly?? If it still doesnt work after the entire assembly is swapped then maybe something from the roof area is hanging down or something is binding up, or the assembly is tweaked or something? <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\">
#6 Guest_baccaruda_*
  • Guests
Posted 10 August 2003 - 01:06 AM
Hi Mark.. I've tried assisting it in several different directions in varying degrees of gently :P no luck, it just stops
Hi JC.. I have one of those but I'm going to put it in the back instead as I think the stock one is too dim. And it doesn't have sunroof controls.. thanks though
Hi Caleb.. I don't think it's a lubrication issue as the motion just stops.. I can try it but I think it's pretty clean..
Hi Mike.. I just changed the motor itself from the one i saved from my old wagon.
does this draw power from a relay somewhere?
#7 Guest_Flowmastered87GL_*
  • Guests
Posted 10 August 2003 - 01:15 AM
Well if you want the ENTIRE assembly (had cracked glass, you gotta change that) you can have my old one. Its at andrews house right now, but if you are ever in the area (portland, albany or the dalles) its yours.
#8 Guest_chef tim_*
Guest_chef tim_*
  • Guests
Posted 10 August 2003 - 07:16 AM
I caught a rock in one of my runners during a 4X4 outing, drove me nuts trying to figure it out. Think I had to "feel" around for it. Tim
#9 Guest_Hondasucks_*
  • Guests
Posted 10 August 2003 - 02:20 PM
Try cranking it open by hand, if it doesn't crank open by hand either, you might have a mechanism issue, like a missing gear tooth or something.
