FWD Impreza to AWD using Legacy stuff ?
3 replies to this topic
#1 P K
P K
    Devil Dog Liaison
  • 1,171 posts
  • Omicron Persei Diego
Posted 03 August 2004 - 09:47 AM
Hello all,
I have an opportunity to get a 1993 FWD Impreza 5 speed. Will my 1990 Legacy AWD 5 speed and rear diff, hubs, axles, arms, suspension, etc, driveshaft (length) bolt up to it? Do I need to change gas tank?
thanks, PK
#2 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 03 August 2004 - 11:37 AM
everything should bolt up fine. Only questionable thing is driveshaft length. I'm not 100% sure about it.
Yes you will need to swap the gas tank as well......and you might as well just swap the whole rear subframe.
#3 P K
P K
    Devil Dog Liaison
  • 1,171 posts
Posted 03 August 2004 - 11:57 AM
Thanks Josh. I was on LegacyCentral looking about (seriously good site), but wanted to confirm that it would BOLT UP, as in: the holes are already there in the Imp, so I am not welding it up. I dont mind cutting a driveshaft. Will the Legacy gas tank fit the Impreza? thanks in advance, PK
#4 Legacy777
Legacy777
    Moderator
  • Moderator
  • 12,809 posts
  • Houston, Tx
Posted 03 August 2004 - 04:47 PM
the holes should be there, as the impreza was based off the legacy. Really couldn't tell you about the gas tank though. You may want to check the owner's manual if you have them for gas tank capacities for the AWD models. If they're the same....they should fit.
If you cut the driveline, make sure to have it rebalanced.
