would an 87 4x4 turbo 5spd most likely have a rear LSD?
Guest justin123
Guest edrach
Even less likely than that. The LSD was optional on the Turbo, but most didn't spring for it. I believe it was standard on the '89 GL-10. Certainly standard on the RX.
Guest UltimateRX
Well, your question is, "would it be likely??", to that question the answer is as Ed said, "NO!!" But does that mean that it won't have a LSD, no, it still could since these were an option on most years. There are only two series that I can say for certain have LSD rear diffs, one being all RXs with manual trannys (yes, they did make thim with autos, but only in 89), and all GL-10 turbos with 4WD in 1989. Outside of those, you'll need to keep looking, because they have been found on other cars then those I have mentioned.
Wagon Wagon was close, if you flip the coin and it lands on it's edge, that is closer to how likely it would be.
