What oil is everyone using?
16 replies to this topic
#1 Guest_oregonloyale_*
  • Guests
Posted 08 August 2003 - 01:23 PM
Im going to try and get the tick out of my valves this weekend with the oil and MMO method. My 92 EA82 has 95k on it and the people who I bought i fromd said it has been doing it since 28K. I did flush the engine , then filled with 10W40 castrol and a quart of thick oil treatment , and this did nothing!So anyways just want to know wich brands are recommended? I think Im going to use 20W50 of something. I live in salem Oregon and am hoping this wont be to thick for the colder months?
#2 Guest_jon61484_*
  • Guests
Posted 08 August 2003 - 01:28 PM
I live in Scio, which is about 24mi from the north end of salem.
I have used 10w30, 10w40, and 20w50 mixed with MMO.
the 10w30 was too thin, and you could hear it. the 10w40 always seems inconsistent. until it's been warmed up for a while, it seems like starting isn't as smooth as the other oil weights.
20w50 quieted it down (with MMO of course!) and it always started up nice. Just right when I hit about 2500 mi on this oil, it got back to being a little noisy.
I say the oil + MMO.
#3 Guest_syphon_*
  • Guests
Posted 08 August 2003 - 01:30 PM
3 quarts 20W 50
1 quart Marvel Mystery Oil.
Still clicks like mad...
#4 Guest_oregonloyale_*
  • Guests
Posted 08 August 2003 - 01:31 PM
but what brand is evrybody using ?
#5 Guest_xenongod_*
  • Guests
Posted 08 August 2003 - 01:48 PM
Okay...well...it almost doesn't really matter too much these days...Pennzoil and Quaker State are the same company...same as most other well known names. Valvoline and Mobil are two of the better oil companies who have remained independent in their refinement methods and tests....so that means I use and trust faithfully both of those brands...Valvoline 10w40 in Subaru...Mobil 1 Synthetic 10w30 in my Mazda...and whatever in my wife's car...she don't care. If your car has leaks...DON'T use synthetic...it will end up leaking more...closer molecules in short. I have talked to veteran mechanics through my years and I always see them installing Valvoline oil and live by it...so...that's it.:smokin:
#6 Guest_edrach_*
  • Guests
Posted 08 August 2003 - 03:59 PM
Castrol 10W-30 or combination of 20W-50 + MMO works for me. If it still clatters, you might look at the mechanical fixes in the other valve clatter thread.
#7 Guest_GeneralDisorder_*
  • Guests
Posted 08 August 2003 - 05:41 PM
I too like castrol 20w50. Little expensive, but it has done well for me.
#8 Guest_Flowmastered87GL_*
  • Guests
Posted 08 August 2003 - 05:42 PM
I live in Beaverton and/or The Dalles and I run Castrol 20W50 year round. I get a little valve noise on startup for like a second (thicker oil takes longer to circulate) but then it quiets down very nicely.
#9 Guest_Ratty2Subaru_*
  • Guests
Posted 08 August 2003 - 07:09 PM
I use Castrol 10w30, and sometimes a little marvel mystery oil!
seems to work the best so far! (and the marvel cleans it out well!)
#10 Guest_WagonsOnly_*
  • Guests
Posted 08 August 2003 - 09:00 PM
I run Mobil 10W40 in my EA82s (cheap and available), Quaker State 10W30 in the Forester (that's what the dealer uses) and Ryobi weedwhacker oil for 2-stroke motors in my 360.
#11 Guest_tomrhere_*
  • Guests
Posted 09 August 2003 - 12:05 AM
Running Mobile 1 15W50 in my '82 right now, we'll see what happens when winter returns. Think I have Quaker State 10W30 in the '86,:rolleyes: , been so long since it's been on the road, I don't really remember:( . Gotta get the exhaust fixed on it, in process of amassing the parts......Tom
#12 Guest_tompalushock_*
  • Guests
Posted 09 August 2003 - 01:05 AM
I read where in the older type engines[i have a ea81, with about 140g's on it. Anyhow, i use straight 40 weight oil from Castrol, also added a bottle of cd2 for oil burning. As long as you have a good battery, it is no problem to turn the car over[i live in Florida} have driven around 800 miles, used to leak pretty good from around oil pan and filter. That is almost non existent now, and the oil reading is still right on full, and the oil still looks clean. It was worth it.
#13 Guest_jimbo747_*
  • Guests
Posted 09 August 2003 - 12:23 PM
I'm in the Phoenix area. I use 20W50 year-round in by '87 GL Wagon and '93 Loyale.
#14 Guest_Biffbradford_*
  • Guests
Posted 09 August 2003 - 12:52 PM
I ran 20w50 Castol in my '87 XT Turbo all last winter, started right up at -10F without plugging in the block heater ... and when I did plug in, forget about it, it started just like summer. I haven't heard lifter noise in over a year. :P
John Wilke
#15 Guest_Skip_*
  • Guests
Posted 09 August 2003 - 01:07 PM
put my check mark beside
Castrol GTX 20w/50 with 8 oz of MMO every 3000 mi
Pittsburgh area all year long, no noise
oil temp 250 - 270 deg F year round
#16 Guest_Mac_*
  • Guests
Posted 09 August 2003 - 05:51 PM
Castrol 20-50 all year long and I try to change every 3K miles under power. My home base is Louisiana. I've been using the GTX with a Fram X2 filter and just started trying the "High Mileage" stuff with same filter. 187K on my '85 GL SW, 30K of that since 1 MAR 03, about 15K under power, the rest under tow while the odometer still ticks off miles.
Had been using Marvel Mystery Oil but a friend recommended Sea Foam so switched to that recently. May switch off and on. I used the SW in my work and put a lot of miles on it in a short period of time.
#17 Guest_snowstormer_*
  • Guests
Posted 09 August 2003 - 06:06 PM
i have a wagon [ea82] 125k. had just 1 clackety lifter. otherwise motor ran real nice. i put in mobil 1 synthetic 15w-50. fired it up with high hopes. still clacked the same.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\"> drove it to work the next morning. [50 miles]. put an ear to the motor before turning it off, clack gone!:D drove about 500 miles since and clack gone. fair oil pressure so im gonna replace pump and seals before winter just to treat it right but i was real amazed at what the oil did.
