Hey everyone, I've got a rattleing noise from somewhere at the base of the shifter on my 98 manual trans Outback. I've checked and ruled out the heat shield.
This noise, is independent of speed, and rpms. It rattles most in 3rd, and I can make it go away if I hold the base of the shift lever. Anyone get this? Find a solution?
How hard is it to get the plastic and leather boot apart to look at the linkage at the base of the shifter. Any tips?
Jeff
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Shifter rattle on 98 Outback
Started by
Guest_smallwavesurfer_*
, Jan 14 2003 11:41 AM
2 replies to this topic
#1
Posted 14 January 2003 - 11:41 AM
#2
Guest_nuburu2_*
Posted 14 January 2003 - 03:44 PM
Jeff, You may want to check the shift bushings for tightness before you tear out the boot. To access them it's a trip under the car, after it's cooled somewhat, as they are near and above the exhaust. These should help;
www.scoobymods.com/forums...readid=564
Glenn O
Glenn O
#3
Guest_rigfennid_*
Posted 14 January 2003 - 11:51 PM
My 97 5sp OB does that rattling too. You probably need to get under the pleather boot in your console and tighten the bolt & nut you see there. I'm going to Home Depot to get a rubber-backed washer to put in to help with losing tension over time, and more dampening.
