98 OB at tx downshifts 2 gears = neutral
No replies to this topic
#1 snide
    New User
  • Pip
  • 4 posts
  • edmonton
Posted 15 October 2004 - 02:20 PM
I recently purchased this vehicle and drove it immediately 2000 mi on a trip.
One problem, which I knew about and was compensated for, is that when the auto
transmission drops a couple of gears on a hill or when u floor it, the engine
races like its in neutral until the gear catches. It spent the day b4 I left in
the subaru dealership and they came up with a few guesses as to what it could be
but basically new transmission seemed to be order of the day. As it seems to
work fine otherwise the guy I bought it off said why dont u drive it until its
totally pooched. If it only drops 1 gear it seems fine!
Anyway when I got home I checked the tranny dipstick and fluid seemed bubbly on
it hot and when I checked it later cold the fluid level is uo over the hot mark.
I took a pint or 2 out of the tranny, doesn't look like there's coolant or water
in it but it never drops the level. Right at the end of the trip the heat gauge
showed the radiator in the red H and I had smelt the coolant dump just b4
looking at the gauge yet when I got out, there wa little steam and I could undo
the cap with my bare hand!! The fluid level in the radiator seems fine now.
So the ?'s are: Why only a problem when downshifts 2 not 1 gear? Why would the
tranny fluid be over the hot mark when cold and I've taken lots out? Why would
cooling system dump whatever fluid in it yet be fine later?
after org post
Have added fluid back & checked level at hot only. Still problem.
