90 Legacy AC Controls
Every now and then the controls for AC vents etc seem not to function...no blower. This seems to occur more when the car has been parked for a while. I can play with the buttons and susally it will kick in. Anyone know the cause and solution
  • 2 weeks later...
Guest redeyerider
To solve the same problem, I took the dash off (a pain), disconnected the hot/cold cable where it ends down in the passenger footwell removed the cupholders and unscrewed the control box, so I could pull it out far enough to wiggle the main electrical plug in the back of the box - that proved to be the source of the trouble. It needed pressure on it to make a decent connection. Fortunately, it plugs into the back of the box in such a way that you can jam something under the plug (about the thickness of a pencil or pen - in my case an old allen wrench) which should create some upward pressure and renew the connection. It's worked for about two months straight, but I haven't put the dash face back on (another pain) just in case.
