were can i find service bulletins from long ago?
Guest archemitis
Guest archemitis
i guess tsb 02-88-93 has some info i would like to get, but i cant find anything about it anywhere. its about the cracks between valves in ea82s. if i show any machinist my cracked head, he laughs and says get a new one. but supposedly sometimes it ok. somebody help me out here.
Guest GlCraigGT
The aftermarket service manual, on CD, I have came with the service bulletins :) I went and posted a PDF of the one in question here.
<a href="http://home.attbi.com/~c.moe/EA82head.pdf" target="top">home.attbi.com/~c.moe/EA82head.pdf</a>
It's not exactly the same as the one from Subaru, the information is a direct quote, the graphic is the same, it just dose not have the offical Subaru letterhead.
Craig, thank you very much here is what his pdf file says
TECHNICAL SERVICE BULLETIN
CYLINDER HEAD CRACK BETWEEN THE VALVE SEATS
Model Subaru L-Series & Loyale (1.8L MPI & SPI OHC Engines)
Group Engine
Bulletin No. 02-88-93
Date February 5, 1993
NOTE: Do not replace cylinder heads for a crack between the intake
valve seats.
Some cylinder heads may exhibit cracks between the intake and
exhaust valve seats. These "bridge cracks" do not cause coolant
leaks or result in valve seat movement. "Bridge cracks" are cosmetic
in nature, and do not justify replacement of the cylinder head. See
Fig. 1.
Production Changes to Prevent Bridge Cracking
1. A chamfer was made between the valve seats and the cylinder
head.
2. Distance between the intake and exhaust valves was increased.
This condition does not affect the integrity or durability of the
cylinder head nor the operation of the engine.
Guest GlCraigGT
I only got 2 of the disks for roughly the same price:mad: but that's how ebay works. I am disapointed in a couple of items with it. There is nothing on transmissions execpt how to change the oil and no photos, just some drawings.
Guest archemitis
thanks alot, i have been trying to find that for about a week. im sure its somewhere in the archives, but i couldnt find it. this could save alot of people $400, because the second a machinist sees that crack he says its shot. thanks again. these discs sound interesting, better than a chiltons, i bet.
