Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
EA81 Hitachi Carb rejetting
#1
Guest_brattysvx_*
Posted 24 August 2002 - 05:22 PM
#2
Guest_Skip_*
Posted 24 August 2002 - 08:16 PM
#3
Guest_beauregaardhooligan_*
Posted 24 August 2002 - 11:58 PM
#4
Guest_brattysvx_*
Posted 25 August 2002 - 07:40 AM
#5
Guest_Skip_*
Posted 25 August 2002 - 08:29 AM
Do you by chance remember changing the "power valve"???
I have seen these work loose (and go bad). Since they are located below the fuel level in the bowl, if they are loose and or "leaking by". The engine will run rich, and as you said, get progressively worse.
#6
Guest_brattysvx_*
Posted 25 August 2002 - 10:08 AM
#7
Guest_Skip_*
Posted 25 August 2002 - 10:34 AM
Some kits have one some don't,
this could still be the problem if it is leaking
or "passing gas" when it shouldn't
#8
Posted 25 August 2002 - 10:58 AM
Did you replace the float valve seat and needle? There is also a filter screen in front of the float valve, be sure it's clean. Blast out any little hole/passage you can find. :cool: Wear glasses!
What about the fuel filter(s)?
#9
Guest_brattysvx_*
Posted 25 August 2002 - 01:10 PM
#10
Guest_brattysvx_*
Posted 29 August 2002 - 02:00 PM
#11
Posted 29 August 2002 - 10:16 PM
If you lose power in a hard right you need to raise the float level.
#12
Guest_rubuild_*
Posted 31 August 2002 - 04:56 AM
a massive vacuum leak or plugged idle circuit, sounds like your other carb is in better shape, reset float levell and check vacuum routing. Check that the bowl vent valve ( black round valve that clips into back of air cleaner) is connected to the very top port of carb, above fuel line fittings & not the secondary air control port on the back side. If fuel is spitting from the primary venturi at idle, you have a plugged idle circuit, and it's sucking fuel from the main circuit.
#13
Guest_brattysvx_*
Posted 31 August 2002 - 09:56 AM
#14
Guest_Subi81_*
Posted 31 August 2002 - 10:42 AM
Good luck
