Guest SubeWitSubs Posted July 24, 2002 Share Posted July 24, 2002 hey all i have a 91 loyale with power windows. as of late i havn't been able to use the drivers side controller to role up the rear windows at all. i can put down the rear windows but not have them come back up with the drivers side controller, and i can't even put the passenger window down or up anymore. at times the passenger side window won't work also. i tried replacing the controller with one that i got at a pull-a-part and that didn't work. any help would be helpfull thanks. Andrew Link to comment Share on other sites More sharing options...
Guest Turbone Posted July 24, 2002 Share Posted July 24, 2002 You need to pull the motors and clean the brushes and connections. Well at least clean the connections before you resort to pulling the motors out:lol: Rob Link to comment Share on other sites More sharing options...
Guest subarustyles Posted July 24, 2002 Share Posted July 24, 2002 the EXACT same thing is happing on my 88 gl wagon ...... I tried a new drivers control unit and it didn't help...... It may be the grounds? Link to comment Share on other sites More sharing options...
Guest chef tim Posted July 24, 2002 Share Posted July 24, 2002 You need to pull out the passenger seat and the door sill plate. Lift up the carpet and you will see a wire junction, one red into three red wires. I will put 98% that those wires are corroded or not connected at all. Just make a new splice and your window problems will be fixed. This is the big voice of experience speaking Tim Link to comment Share on other sites More sharing options...
Guest Brus Brother Posted July 24, 2002 Share Posted July 24, 2002 90 loyale. Driver controller works fine but passenger side switch only lowers the window. It must be raised using the driver side controller. Any thoughts? Link to comment Share on other sites More sharing options...
Guest Spiffy Posted July 24, 2002 Share Posted July 24, 2002 I'm having the same problem with my '92 loyale... I have to tweak the buttons on the master panel to get the rear windows to roll up, it's tricky but it's usually easier than reaching back and using the controls on each door... I'm gonna try tim's advice and look under the passenger seat for some corroded terminals... it sounds easier than taking off the door panel... but like I said, if I just tweak the switch to one side it will work, that leads me to believe it's something in the master switch panel and not something further down the line... *shrug* Link to comment Share on other sites More sharing options...
Guest chef tim Posted July 24, 2002 Share Posted July 24, 2002 The switches will work intermitantly because they draw enough power to drop the window but not raise it. or visa-versa. I went through heck trying to figure this out, Qman clued me in!!! Later, Tim Link to comment Share on other sites More sharing options...
Guest Floid Posted July 24, 2002 Share Posted July 24, 2002 Wiping down the rubber seals with some pure ammonia (50% dilution is probably better, but I'm the lazy type) can soften them up/clean them, which helps if the motors are weak for any reason. I wouldn't do that on the foam stuff around the door edge, though, just the wiper-like rubber. Sounds like the trouble is more severe than that here, but it's a handy tip, works well on new blades, too. (Got it off a pack of Tripleedges we used once, never going to bother with those things again.) Link to comment Share on other sites More sharing options...
Guest kelowna kid Posted July 24, 2002 Share Posted July 24, 2002 I would check the wiring harness to the driver`s door. In my experience, wires are often broken here due to frequent use of that door. Link to comment Share on other sites More sharing options...
Guest baccaruda Posted July 25, 2002 Share Posted July 25, 2002 I disassembled the actual switches and cleaned them with emery paper .. they work fine now. I'll remember "cleaning the brushes" and the passenger seat/wires tricks, might come in handy but I think it's best to start with what's simplest.. Link to comment Share on other sites More sharing options...
Guest Brus Brother Posted July 25, 2002 Share Posted July 25, 2002 Heading baccaruda's suggestion learned from Qman, I finally took the door panel off today. 2 screws and a bunch of push in connectors, lift the top over the lip and you are there. Switch still attached to door panel. Quick electrical disconnect from switch. IMPORTANT, now move to a place where you won't lose little parts in a gravel driveway as I did. DOH! Switch comes apart pretty easy and there was carbon buildup on contacts. Light sanding and they are ready to go. If you ignored IMPORTANT above, spend next half hour sifting through gravel and then reassemble parts. Mine was the passenger side switch that was dirty but if you can wiggle your switch and get it to work, my guess is that your contacts need cleaning. PS After I dropped the two rollers, the size of a sesame seed, I think I recall that Qman also cautioned as above.... but who listens! Link to comment Share on other sites More sharing options...
