Guest McBrat Posted April 4, 2000 Share Posted April 4, 2000 torsion bars are broken. can't get them out without pulling tube off car, and that doesn't look likely to happen because of rust... someone mentioned before about possibly putting rear struts from a newer 4wd wagon (newer than ea81). any thoughts on how to do this, or any other ideas of what I can do to lift up this current low-rider.... Quote Link to comment Share on other sites More sharing options...
Guest scoobydoo Posted April 5, 2000 Share Posted April 5, 2000 You would need a solid axle, and the mounts need to bolt somewhere. Quote Link to comment Share on other sites More sharing options...
Guest McBrat Posted April 26, 2000 Share Posted April 26, 2000 got some rear struts off a 85 4wd wagon. need to fabricate a bracket for the top for the mounting, but looks like it will work. if I try to use one of the existing holes though, the rear of the bat will sit up so high I may not be able to see out the rear mirror ha ha ha... the strut is a few inches taller, and the top mounts are wider... Quote Link to comment Share on other sites More sharing options...
Guest McBrat Posted April 28, 2000 Share Posted April 28, 2000 The BRAT LIVES!!!!! The bottom of the differential is 11 inches off the ground, and I think this is within the limits... Anybody know? I ended up getting a 2 inch wide piece of 3/16 thick steel. cut extra long to add another bolt through the bed if I want, but I didn't. drilled 3 holes center one is used to mount the steel bar into the rearward bolt hole from the original shocks. bought metric bolt 1 inch longer than original, and added washers between strut and mount plate (to help keep the springs away from the body), and bolted into forward original shock bolt hole. Then bolted the other side of the strut mount to the third hole in the bar, with spacers in between again. took it out for a test spin. definitely better than the body resting against the trailing arm. Still rides like a lumber wagon (but what old soob doesn't ) The suspension is a little stiff, and I didn't get it away from the body enough, so there are some interesting noises as the springs move now to swap in a different tranny, and maybe get a windshield... When I get a nice day where I'm home when the sun is out I'll take some pics... Quote Link to comment Share on other sites More sharing options...
Guest McBrat Posted April 28, 2000 Share Posted April 28, 2000 you can see the before pic here, under Current Subes, 82 Brat - Black: <a href=http://members.xoom.com/mick82/mysubes/mysubesfr.html>Old Pic</A> Here is the new pic: <img src=http://members.aol.com/redscab/82brat2.jpg> I have a pic of the new mount I will have Shawn put in the on-line manual... just in case... Quote Link to comment Share on other sites More sharing options...
Guest McBrat Posted May 2, 2000 Share Posted May 2, 2000 here's what the strut mount looks like: <img src=http://members.aol.com/redscab/strut2.jpg> Quote Link to comment Share on other sites More sharing options...
