AussieIan Posted November 15, 2004 Share Posted November 15, 2004 Hi people. My front suspension bushes including the sway bar bushes are quite worn. Are they a pain to replace? Do you need a press? Do I stick with rubber or go to nolathane. Any feedback greatly appreciated. Thanks Ian Quote Link to comment Share on other sites More sharing options...
Legacy777 Posted November 15, 2004 Share Posted November 15, 2004 I'd probably replace the anti-sway bar bushings with polyurethane ones, as well as get new end links. The front bushing on the control arm is pressed in, and you'd need a press for that. I'm not sure of any aftermarket bushings for that one. The rear bushing on the control arm should be able to be removed without taking off the control arm. I'd suggest talking to whiteline and see what they can offer you. Quote Link to comment Share on other sites More sharing options...
