traci Posted December 2, 2004 Share Posted December 2, 2004 My right outside brake light is out on my 95 Legacy Sedan. I checked the bulb and it is fine and fuses all look good, but still no light. I changed the bulb, and wiggled the wires and that did not help. Any ideas?? Thanks. Quote Link to comment Share on other sites More sharing options...
Setright Posted December 2, 2004 Share Posted December 2, 2004 Did you replace the bulb with the correct type? It might be a dual element bulb. I suggest getting someone to press the brake (heavy objects can do the trick) and using a voltmeter to measure for voltage on the socket terminals. Bear in mind that a new bulb could be bad. BY the way, are the terminals in the socket clean? Quote Link to comment Share on other sites More sharing options...
traci Posted December 2, 2004 Author Share Posted December 2, 2004 Found problem, 2 bad bulbs, thanks for help. Quote Link to comment Share on other sites More sharing options...
