MudisFun Posted January 26, 2005 Share Posted January 26, 2005 I just got done setting my engine back into my 85 GL-10 after a head gasket job. Got confused when getting the distribtor back in but all when well. She started like crap, still that was a good thing - she started. I yanked out the distributor again and set the crack the 0 deg on the first cyl. Now that the timimg should be better the engine won't fire. I hooked up a timing light and cranked the engine, nothing... So here is the question: Should there be a link between the top "pick" metal and the metal inside the rotor, the plate that connects to the distributor? I checked for ohms and there is not a connection. Quote Link to comment Share on other sites More sharing options...
85Sub4WD Posted January 26, 2005 Share Posted January 26, 2005 Are you sure you are at TDC on #1? where are you checking your spark? from the coil or from a spark plug wire? unless you rebuilt your disty, everything should work. If you are 180-degrees off and you are checking a sprark plug wire with a timing light you will not get a pulse. As you have done the heads, it might be a good idea to convert to SPFI and be done with the carb system in the future. I am sorry but I cannot remember what the continuities should be, but if you did not mess with the disty, it should still be good Quote Link to comment Share on other sites More sharing options...
MilesFox Posted January 26, 2005 Share Posted January 26, 2005 Are you sure you are at TDC on #1? where are you checking your spark? from the coil or from a spark plug wire? unless you rebuilt your disty, everything should work. If you are 180-degrees off and you are checking a sprark plug wire with a timing light you will not get a pulse. As you have done the heads, it might be a good idea to convert to SPFI and be done with the carb system in the future. I am sorry but I cannot remember what the continuities should be, but if you did not mess with the disty, it should still be good you are probobly 180 off. remember, there are 2 crank rotations for every one cam rotation. to double check the passenger side cam dot will be pointing around 10 o clock position at odeg tdc Quote Link to comment Share on other sites More sharing options...
