Guest Tbone965 Posted August 5, 2003 Share Posted August 5, 2003 I got a 86 Subaru GL, on checking the choke, can this be done with a test lite? I turn the ignition on, and get no lite when I put it to the wire going to the choke, (testlite grounded to battery - terminal) The fuse is good, and i see no bad wire all the way to the firewall...<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/ohwell.gif ALT=":\"> Quote Link to comment Share on other sites More sharing options...
Guest GlCraigGT Posted August 5, 2003 Share Posted August 5, 2003 i would think it can be tested with a light. See if you can get the light to come on with the engine running. Quote Link to comment Share on other sites More sharing options...
