front end vibration
Guest scubabike420
I have a front end vibration and I believe I have found the source of the problem. When I grab the tie rod on driver's side I get some play on the inner end. I see a long boot on this end. What's under this and how hard/expensive is it to replace?
'95 Legacy Wagon
there's a snap clip hidden under there
it's not a 'fun' swap by any means but it totally doable.
part should cost $20-30ish
contact me if you want to verify
i can get you a quote with 20% off...
parts are new from subaru
good luck!
Jamie
A little play, up and down, is not exactly optimal, but it's not dangerous and won't cause vibration.
Play out and in, is someting to worry about, and since wheel direction control suffers, this could cause vibrations.
Which way can the rod move?
