MiniTransAm Posted May 19, 2005 Share Posted May 19, 2005 OOps just posted this in OT, doh! Anyway, the drain plugs are loosened for the rear diff and the transfer case with a 3/4" drive ratchet correct? Or do I need to buy something else. I got a 99 OBW Auto Quote Link to comment Share on other sites More sharing options...
MiniTransAm Posted May 19, 2005 Author Share Posted May 19, 2005 doh, I meant 1/2" Quote Link to comment Share on other sites More sharing options...
jukeit Posted May 19, 2005 Share Posted May 19, 2005 I called the dealer a while back with the same question. 1/2" it is. Quote Link to comment Share on other sites More sharing options...
Scottbaru Posted May 19, 2005 Share Posted May 19, 2005 Be sure you loosen the fill plug first. I've read many posts where the lube is drained and the fill plug is stuck. Bummer. Quote Link to comment Share on other sites More sharing options...
MiniTransAm Posted May 20, 2005 Author Share Posted May 20, 2005 Excellent just figured I'd check. Have you guys ever heard that flushing a tranny if it has XXX amount of miles on it can be bad??? A guy told me that today at work. I don't see how leaving old, contaminated fluid can better than replacing some of it with clean, new fluid. I'll also make sure I pull the check plug first. Be good to see if the fluid level was right before I drained it anyway. Quote Link to comment Share on other sites More sharing options...
