walterthedog Posted September 12, 2003 Share Posted September 12, 2003 Can someone help me and tell me how to set the choke on my 78??:temper: Quote Link to comment Share on other sites More sharing options...
wagon78 Posted September 13, 2003 Share Posted September 13, 2003 The 78 choke gets set by fully pumping the gas pedal when the engine is cold. A bi-metallic spring and a rachet assembly in the choke housing forces the choke plate nearly shut when cold. After starting the engine, a heater coil in the choke housing begins heating this bi-metllic spring which begins to apply an opening force to the choke plate. Progressively tapping the gas as the engine warms releases the ratchet mechanism and lets the bi-metallic spring progressively open the choke plate. Is your choke not closing when cold, or not opening as the engine/choke warm up? Scott Quote Link to comment Share on other sites More sharing options...
walterthedog Posted September 15, 2003 Author Share Posted September 15, 2003 My problem with the choke is i took it apart and now can't seem to get it set so it operates correctly.:madder: :madder: Quote Link to comment Share on other sites More sharing options...
