dromond Posted August 11, 2005 Share Posted August 11, 2005 I'm looking to buy a used Impreza wagon with a manual trans. From what I gather the 2.2L engine has many fewer reliability problems than the Phaze I & II 2.5L. It also appears that the head gasket issues began around 1998. I assume this is just with the newer 2.5L engines. What I'm wondering is if the 2.2L engines in the 1998-2001 models are mostly the same as the pre-98 models? My main goal is to find a well-maintained, reliable vehicle; and I don't need the extra power of the 2.5. Is there any reason not to go for the 2.2? From a reliability standpoint, what are the other major differences between the 97-01 models? I apologize for my meager knowledge, but then again that's why I'm here. cheers Quote Link to comment Share on other sites More sharing options...
redwagon Posted August 11, 2005 Share Posted August 11, 2005 What you're asking is of course a matter of opinion, but I think most people would agree on a few things. The EJ22 does seem to live longer, given the same treatment. The DOHC EJ25 has issues with it's head gasket, many have been replaced. I don't recall similar problems with the EJ22. OTOH, the phase I EJ22 heads don't flow well and this limits power potential. The phase II heads flow better, but have a single exhaust port per head. I think only Borla has a header to fit it. The 99+ phase II SOHC EJ25 seems very reliable and most agree it's a much better engine than the phase I. There was a TSB to put some sealant in the cooling water, and a few gaskets were replaced. Nothing like the scale of the DOHC problem though. But anyway, there was no Impreza wagon with a 2.5 until the newskool TS, so you're either getting an L or Outback Sport with a 2.2 97/98: solid, but poor heads. 99: better heads, more power, poor header choices and fragile MAF sensor. 00/01: ditto, but somewhere along the line they changed to a MAP based OBDII ECU. Can't tune with S-AFC. Check out cars101.com, lots of Subaru info there. Quote Link to comment Share on other sites More sharing options...
