Guest unix Posted July 26, 2003 Share Posted July 26, 2003 I am in the process of stripping my parts rust bucket. Question arises, what should I do with the remains? It won't be able to be towed, I don't want to eat the cost of a tow. Can I cut it up and haul the remains to a metal scrap yard myself (I have a truck). What are my options? Quote Link to comment Share on other sites More sharing options...
Guest Flowmastered87GL Posted July 26, 2003 Share Posted July 26, 2003 You should be able to cut it up with a sawzall and then take it to a steel recycler and get like $45 a ton for it Quote Link to comment Share on other sites More sharing options...
Guest moosens Posted July 26, 2003 Share Posted July 26, 2003 You lucky dogs out west get that much.Right now scrap steel is worth a frog's fart on the east coast. I recommend the "Torch" blades Milwaukee has.Get a couple long ones and a couple mediums.Don't waste your time getting short ones.They're great for plumbing removal,etc. but for cutting up a car the longer sizes work best.Trust me,been there,done that. You've been on the board for 4 years.Could you offer a location in your bio.?? I just now saw the other post....in VA,not sure what scrap is there but it can't be much. Cutting a Loyale huh....is the windshield any good? Quote Link to comment Share on other sites More sharing options...
Guest unix Posted July 26, 2003 Share Posted July 26, 2003 It looks like I found the solution I was looking for. Sawzall. Looked on ebay, they have lots of them, any good model you can recommend? I have a full size truck, maybe if I cut the car into 2 pieces, it can fit in there. Although to lift these pieces into the bed, it would have to be cut into 3 parts, I imagine. Where exactly do I cut it, does it matter? Should the tranny be removed first? <strong> Cutting a Loyale huh....is the windshield any good? </strong> The windshield is perfect. If you want it -- I don't know if windshields can be shipped. rec.autos.tech discussion Quote Link to comment Share on other sites More sharing options...
Guest magnificent subaru Posted July 26, 2003 Share Posted July 26, 2003 Don't waste the opportunity to make yourself a "wicked chopsaw" a-la modified chainsaw arm with a 10" or so cutting disc. Them's danger sports! (Don't try at home) (Forget I said anything) Ross in Idaho On a helpful note, I found the "search and rescue" blades for sawzall at home dumpo. Thicker, cuts better without bending and flapping. RAH Quote Link to comment Share on other sites More sharing options...
Guest northguy Posted July 26, 2003 Share Posted July 26, 2003 Or rent a hot saw from the local rental place. As far as reciprocating saws go, it's hard to be Milwaukee sawzalls. The supersawzall isn't as good as the original, though. Dewalt makes a good one with an easy change option that's handier than the old allen screw on the Milwaukees. Personally, I'd drop the $40 to rent a Stihl hot saw and go at it. Quote Link to comment Share on other sites More sharing options...
Guest unix Posted July 26, 2003 Share Posted July 26, 2003 what Milwaukee sawzall model works best? Quote Link to comment Share on other sites More sharing options...
Guest archemitis Posted July 26, 2003 Share Posted July 26, 2003 but keep in mind they wont take it without a title. Quote Link to comment Share on other sites More sharing options...
Guest unix Posted July 26, 2003 Share Posted July 26, 2003 I thought it only applied to un-cut junkers. In any case, I have the title. Quote Link to comment Share on other sites More sharing options...
Guest DaveAP Posted July 26, 2003 Share Posted July 26, 2003 When using bimetal blades, try to have a little patience, and keep the cutting speed on the slow side. If you cut too fast the teeth wear out alot faster. Also always say "god bless my sawzall" after using. Quote Link to comment Share on other sites More sharing options...
