Ign key switched headlights in Gen I's
I own several Subaru’s and I have gotten into the habit of leaving the headlights on at all times.
When I got my first Gen I Brat I was bummed because
the headlights did not turn off with the key like my other Roo’s
I went in search of an EZ fix.
My local NAPA dealer had the answer.
It is a lighting relay with a built in fuse.
They also had clips that allow you to tap into the
old style fuses that the Gen I’s use.
Now I was armed with the above relay and three fuse clips.
I needed a “blown” fuse
(to toast one if you don’t have one, just connect two leads from the battery across it - poof.)
The relay “built in” fuse should match the headlight fuse in the vehicle.
It was a simple matter to wire the relay to turn on with the key.
I used the ignition controlled fuse in the fuse box
via one of the fuse taps I bought.
I then grounded the other side of the relay coil.
I replaced the headlight fuse with the blown fuse and the other two fuse taps.
To these I wired the relay contacts.
No worries mate. headlights turn off with the key.
I took the liberty of showing a simpler method
using an auxiliary lighting relay and a new style fuse.
Crimp on female spade connectors can be used
to make all the connections.
14 AWG wire should be used.
Either way works but the "fused relay" is a “cleaner” method in my opinion.
Click on my board name and email me if you have any questions.
  • Like 1
