Pillowsplat Posted November 1, 2003 Share Posted November 1, 2003 2003 OB Wagon 30,000 miles Its time for new plugs and filter. I was looking at the plug access and they look pretty good except the one Driver side towards the rear of the car. I have pretty big paws and it looked tough to get to. Should I remove the window washer tank or is there another trick? Thanks for the help John Quote Link to comment Share on other sites More sharing options...
loudsuby Posted November 1, 2003 Share Posted November 1, 2003 If it is a 2.2, it should be the same as my wagon. The way I did it was with a "knuckled" extention on the socket wrench, I forget the exact name. Quote Link to comment Share on other sites More sharing options...
WAWalker Posted November 2, 2003 Share Posted November 2, 2003 Yes, remove the washer bottle. Quote Link to comment Share on other sites More sharing options...
AussieIan Posted November 2, 2003 Share Posted November 2, 2003 And use NGK Iridium spark plugs they last a long while, better than 60,000 miles and you get better ignition because of the very thin electrode. :-) Quote Link to comment Share on other sites More sharing options...
Pillowsplat Posted November 2, 2003 Author Share Posted November 2, 2003 Thanks! WW bottle two screws, two cable hooks, pull out of way. Other side 1 screw remove airbox. Regular plugs work fine. Quote Link to comment Share on other sites More sharing options...
DerFahrer Posted November 2, 2003 Share Posted November 2, 2003 Ian is half-right. NGK V-power coppers are the final word in Subarus. There is no better plug, period. It outperforms any other plug you can possible use. The only downside is they don't last 15 minutes:brolleye: ... Iridiums will not quite offer the performance of the V-powers, but they will last much longer... Quote Link to comment Share on other sites More sharing options...
