Uh... since Im looking at imminent clutch replacement myself.. what is clutch judder???
Thanks!
Don
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Clutch judder??
Started by
Guest_dwallbaum_*
, Jul 23 2003 04:47 PM
8 replies to this topic
#1
Guest_dwallbaum_*
Posted 23 July 2003 - 04:47 PM
#2
Guest_theotherskip_*
Posted 23 July 2003 - 07:49 PM
clutch judder (also called clutch chatter or clutch studder) is when the clutch does not engage smoothly, rather slipping and grabbing, usually resulting in the car bucking, usually most pronounced in lower gears.
which way are you leaning with replacing the clutch? i am not too sure which to choose - a subaru replacement or aftermarket. i'm not looking to spend $450 for a high-performance clutch from the likes of act or similar. i'm just a regular driver, and am looking for just a good quality smooth clutch. have you given it any though?
#3
Guest_spagemurray_*
Posted 23 July 2003 - 09:00 PM
New OEM in mine fitted last week is excellent, totally different than the clunker they pulled out. It has new part no dealer told me.
#4
Guest_rtp373_*
Posted 24 July 2003 - 07:47 AM
There's a thread "What's the verdict on the new Subaru clutches" with about 45 entries that I started. I'd read through the testimonials. At one point someone had the service bulletin posted. If your car has under 36,000 miles go get it replaced under warranty. If it's over and you haven' t logged complaints, you probably won't get too far.
Just got mine replaced this week and it is AWESOME. Couldn't beat the smile off my face. If you go stock, make sure to get the same parts on the 2003 model year. Test drive a 2003 forester or OB.
#5
Guest_spagemurray_*
Posted 24 July 2003 - 04:45 PM
Mine was done free 6mths out of warranty so push your dealer hard!!
#6
Posted 24 July 2003 - 10:07 PM
i've been reading the thread on the what's the verdict. it basically only talks about either people getting a free clutch from subaru or people all for act and other pricey clutches. i was wondering if there are any other good performing moderately priced clutches out there...
i've got a 97 leg which has some judder, but is way out of warranty & it isn't dealer maintained, so they aren't likely to cut me a break...
#7
Guest_spagemurray_*
Posted 24 July 2003 - 11:46 PM
I bought mine from a used car lot (A mazda dealer in fact) and a Sube dealer had no trouble replacing clutch 6 mths out of the 3yr warranty. Flywheel machine etc etc. This clutch I can idle out of my garage up a slight incline in reverse from a cold start. That would be impossible with the clutch they removed. Still it appears Sube America is a very different animal than Sube Australia. Hey you have a TSB to wave in their faces, here we don't. Give 'em heaps.
#8
Guest_dwallbaum_*
Posted 28 July 2003 - 01:27 PM
TOS;
Thanks...no problems yet, but I have a '99 Impreza that is probably gonna have the engine replaced,and when that is done, Ill have the clutch replaced also.. car has 150K miles on it so I figure its about time.
At this point, if I have the OEM bits and pieces ordered, will I get the current, sound clutch? Or do I have to specify something?
I dont have any problems with my current clutch.. just anticipating a wear and tear replacement.
Thanks.
Don
Thanks.
Don
#9
Guest_spagemurray_*
Posted 28 July 2003 - 08:56 PM
Replace engine in 99 model with 150,000 miles??? What happened? And yes new clutch is a no brainer with engine out.
