Bleeding brakes: a couple of questions
Well it's been a while but I'm back with a couple of questions about bleeding brakes. How much fluid would it take to bleed at all 4 wheels?
Also, is there any preferred order to follow? I remember reading something along the lines of going from the farthest wheel to the nearest, but Haynes has something different. Any opinions?
Ah yes, I almost forgot: it's a 91 Legacy FWD 5 speed. Some of you might remember me from a while back, I think I last posted in December or January. Earlier this summer I passed the 200,000 km "mile"stone. It was kind of neat to see all 6 digits turn over. I wonder if I'll get to see it happen again...
Thanks
Rt rear
Lt rear
Rt frt
Lt frt
a small bottle will just do it, if I recall. also, stick w/ DOT 3. 4 gives higher boil point, but has just a tad "squishy" feel to it compared to 3. Don't know why, but it does.
Mike
Legacy, I hope you don't mind if I add another question to your post. Should the car be running when bleeding the brakes? also should you pump the brakes or just step on it once?
Now that is an interesting question.
I take by saying "bleed" you just want to remove a bit of air in a line or cylinder. This takes just a small amount of fluid.
However there appears to be a difference in density between brake fluid brands. I recently replaced brake fluid in 2 vehicles using DOT3 specification fluid and there was a clear difference in density. The removed fluid which was darker than the new clearly floated on top of the new fluid.
It did not seem to make any difference to performance
car running? better off. less heat, and you won't accidentaly knock the bleed hose off the nip from too much pressure.
pump vs to the floor. both....pump to the floor, making sure you keep fluid in the reservoir to avoid going dry. keep pumping 'till clear fluid is coming out the bleed hose. then tighten, goto next wheel.
pmonro: I've seen that too. you'd think it'd be the other way, with h2o-saturated fluid sinking to the bottom...
mike
the actual FSM braking bleeding procedure is
front right
rear left
front left
rear right
There's been debate on other boards about the procedure and doing the furthest away first. Me personally have had better luck with the FSM procedure
maybe the 'cross' type is recommended because of the split circuits? I think a lot of cars nowadays have the opposite corners on a circuit and the 'other' corners on a different circuit. So if you loose one half the master cyl. (?) or something (anyone?) you still get one fron and the opposite rear brake working.
Carl
1 Lucky Texan
My bad I should've looked at what meep posted a little more closely.
Yes you want to do diaganol because of split brake systems.
Some people recommend the order to be
LR
RF
RR
RF
