Interference engine, or not?
2 replies to this topic
#1 Guest_Biffbradford_*
  • Guests
Posted 10 July 2003 - 02:06 PM
I bought a '92 Legacy L wagon this past weekend ($1,1000) and I would like to know if it has an interference engine or not.
The sticker on the hood says 2.2 L, so that would make it NOT interference, but it's a 16v ... does that make any difference?
VIN: 4s3bj6320n6909978
(Can someone decode the VIN for me? )
I was told that the car was traded into the dealer at 160k by a traveling nurse (I found this out after the sale), then driven to the current 205k miles by the seller who did not have the timing belts changed. :(
Should I plan on doing that this weekend?
The car runs GREAT, and I'd like to keep it that way.
John Wilke
#2 Guest_Legacy777_*
  • Guests
Posted 10 July 2003 - 03:58 PM
2.2 engines are non-interference.
It probably wouldn't be a bad idea to get the belt done, but if it does break, it won't hurt the engine.
#3 Guest_subyluvr2212_*
  • Guests
Posted 11 July 2003 - 09:31 AM
The car will actually run a tad better with a new timing belt. The old one, at that age and mileage, has definitely stretched, if just a teeny bit. That will alter your timing slightly...
As for the VIN, you already know it's a 92 Legacy Wagon, so I don't need to decode that, the only other thing I can tell from it is that the 4S at the beginning means it was built in Subaru's Indiana plant, and not in Japan.
