highpowerd2003
  1. no diffrence with the fuse, have put around 16,000 miles on car since owned. when cornering can sometime feels a slip. on start to move sometimes it revs a little before trans engaged. just changed trans filter and fluid it made a diffrence with the slipping on start. I was thinking because awd not working was causing slip?
  2. i had it stuck in the mud had to hand push it out only front wheel turning, no help from real wheels
  3. 90 legacy awd, no fuse in, car wont engage in 4x4. auto with 2003000.miles what could be wrong
  4. Hi, I have a 1990 legacy all wheel drive. this car has the fuse under the hood to disengage the 4x4. fuse appears to be OK. what else could make the 4x4 not engage. thanks Dan
  5. been driving a subaru legacy AWD for six months. when starting off it seems slow for trans to engage. sometimes when rounding a curve it feels a slight jerk when trans engages again. Is this normal or something else. car just turned over 200,000 miles. Thanks DAN
  6. hELLO iM NEW TO THIS WEBSITE. i HAVE A 9O LEGACY WITH TEMP PROBLEMS. hAS NEW WATER PUMP AND RADIATOR. i NEED TO REPLACE THEMOSTAT. dO i NEED TO REMOVE THE TOP OF ENGINE, INTAKE, INJECTION TO REPLACE THIS PART. tHANKS dAN
