highpowerd2003
Posts posted by highpowerd2003
i had it stuck in the mud had to hand push it out only front wheel turning, no help from real wheels
how exactly are you testing this? And when it does engage (should always be on) it'll be AWD, not 4x4, with 4x4 you will get some nasty binding when you turn.the best way i've found to test if it's working, it to get yourself high centered on a large snowbank, and see if a wheel in the front & back are turning...
90 legacy awd, no fuse in, car wont engage in 4x4. auto with 2003000.miles what could be wrong
Hi, I have a 1990 legacy all wheel drive. this car has the fuse under the hood to disengage the 4x4. fuse appears to be OK. what else could make the 4x4 not engage. thanks Dan
been driving a subaru legacy AWD for six months. when starting off it seems slow for trans to engage. sometimes when rounding a curve it feels a slight jerk when trans engages again. Is this normal or something else. car just turned over 200,000 miles. Thanks DAN
hELLO iM NEW TO THIS WEBSITE. i HAVE A 9O LEGACY WITH TEMP PROBLEMS. hAS NEW WATER PUMP AND RADIATOR. i NEED TO REPLACE THEMOSTAT. dO i NEED TO REMOVE THE TOP OF ENGINE, INTAKE, INJECTION TO REPLACE THIS PART. tHANKS dAN
4x4 wont engage
Posted
no diffrence with the fuse, have put around 16,000 miles on car since owned. when cornering can sometime feels a slip. on start to move sometimes it revs a little before trans engaged. just changed trans filter and fluid it made a diffrence with the slipping on start. I was thinking because awd not working was causing slip?
