Everything posted by leaksoilknocksclutch
spark plug specs
.040 gap, 12ft/lbs sound about right.
'97 Outback with 120K - Keep or sell?
IMHO, sell it now. You are correct about the miles/price.
New Gen newbie questions.
SIMPLY????????????
Code P0304
I would start with replacing the oxy sensor after (downstream from) the cat and clear the codes. Drive as usual and see if any more codes pop up.
Code P0304
The cylinder misfire code could be as simple as moisture in the gas - if it reoccurs, more diagnosis is required. The catalyst below eff. code could be the oxy sensor after the cat converter (there is 2 on your car - 1 b4 the cat and 1 after). How many miles on the car and have the oxy sensor(s) ever been replaced?
High Miles on your Legacy Outback?
Since there is a lot of talk about head gasket failures in this thread, I have a quick question/comment. Does anyone pop off the valve covers, say every 60K (when changing the timing belt), and retorque their head bolts? Just a thought that may help the head gaskets last longer.
Subaru that starts with a "P"???
Could be a 1.8L - is it AWD?
Regularly crunching reverse
After you push down the clutch, put the tranny in 3rd gear and then over and down to reverse.
How to Treat a Brand New Legacy
Nick, fantastic automotive advise. 100% agree! Here's a couple more neglected items- power steering fluid, PCV valve, tranny fluid (& filter if applicable)
oil weight for a 90 legacy AWD 5spd?
Oh, the tranny. 75W90 full syn.
2001 Forester Transmission removal
WOW, a 99 and a 01 that have tranny issues? YIKES!!
Mobil 1, 10W30
