tommy
Everything posted by tommy
  1. yup, car ON, not in the start. actually, it doesn't spark when you crank it.
  2. hum/hiss = buzzing noise from the engine compartment. It can turn over / run for a few seconds on starting fluid. Every couple trys. I'm really confused about the sparks plug firing randomly on its own. With out trying to start the car.. Just hook the battery up, turn the key to the ON position, pull the plug and wire out, and it will randomly spark. (tried with multiple different plugs) and only one plug at a time. -- i know, the car has lots of issues --
  3. Don't know how to really explain it .. but here goes. Just bought a 92 wagon legacy L for $600 and it wont start. Here's the symptoms: No/Little Fuel Up Front Spark Plug fires randomly.As in. just with the key on, not in start position After you turn it over, seconds later .. poof. Its like a back fire or compression change. 3rd A/C relay in the engine bay from the front clicks like a suno*********un There's a hum/hiss when the keys in on position and i push the throttle linkage. What I've already done: Pulled the fuel pump out from in tank, checked it, works fine. Put 12v directly to pump and got fuel coming out of the return up front. Any ideas anybody on anything above ??
