fldcar
Everything posted by fldcar
  1. Thank you both for your help. Skip, you were right on. It was the switch. I called the local Subaru dealer and they wanted $280 for the part. So, I went to this little u-pull yard and got one for $5. I couldn't find a switch with the intermittent wipers but everything else was the same. P.S. The problem with the front marker light was a corroded contact. Subarus must use different bulbs than other cars. I replaced the LF light (#67 at Walmart) and its the exact same bulb but it is much dimmer than the other side. I don't know why but I remember having a similar problem with my SVX. Thanks
  2. On a side note. I have a feeling that a previous owner may have disconnected the high beams (intentionally or accidentally). Why, I do not know. BUT....so far I've reconnected the power seat belts, door dinger and some sensor under the hood.
  3. The high beams in my '94 Loyale Wagon are inop. I thought the problem was the bulbs as the one low beam did not work, and neither high beam worked. So, I changed the bulbs. Now, both low beams work and when you flip the high beams on nothing happens except the low beams go out. I do not get an indicator on the dash (for the highs)! Please help, I need to get this issue taken care of for state inspection. I've already checked all the fuses under the steering column. Thanks for any help.
