mnewman0
  1. It's an auto and found the fuse holder, looked at the labels, but nothing with FWD. Tires are getting old, but all are the same size and age. Thanks!
  2. Looked in fuse box under the hood, but didn't see any labeled FWD. Do you know where it's located? Is is possible I don't have a FWD fuse? Thanks!
  3. I'm having a problem with my 96 Legacy. When I take a slow turn (like coming out of a parking space) very sharp, the car will jerk a bit, like it wants to shut off. Then, I straighten the wheels and it's fine again. Only seems to happen on very slow, very sharp turns. Any ideas?
  4. I'm baffled about this one ... Car was running great, no issues. Did 3 things to it. 1. Changed the Oil 2. Replaced the air filter 3. Added fuel injector cleaner to a full tank of gas ... Now, the car will turn over and run for like 5 seconds, then the rpms dip down and it shuts off. I can keep it running, only if I start it and then immediately keep my foot on the gas petal ... keeping the rpms above 3K, but the engine doesn't sound so great when I do this. What I've done so far which has made no impact. Changed the fuel filter, checked the oil levels, filter ... all fine, no leaks, disconnected the battery for 15 minutes, to try and reset the computer. Any ideas???
