tommygun
Everything posted by tommygun
  1. sounds easy enough thanks for the response, i did not know those were mechanical linkages. by the way my egr light is now illuminated on dash, could this cause my carb to malfuntion. what should i expect with egr gone bad. thanks again
  2. can someone tell me why the rear barrel on my ea82 carb will not open. the car idles and i have the front barell operating. if i push rear barrel flapper down manually from above with thin screwdriver the gas shoots into the barrel and all 4 cylinders fire. i believe im only getting fuel to 2 cylinders from front barrelll and the car wont drive well stalling sputters hard starts etc.... help b4 the copps pull me over for lurching down the road. thank ye
  3. my 87 gl wagon wont fire up. tested voltage at fuel pump got 0 volts. have 12 volts dc across fuse contacts. tore into dash looking for fried wire harness or bad relay. no such luck. im as confused as the guy who wrote this repair manuel, any help appreciated
