maudsland
Posts posted by maudsland
just saw this for sale, http://page8.auctions.yahoo.co.jp/jp/auction/h183691476
cheers Thierry
Hello, i spoke to Kosta the other day and he said you might have a spare FF1 water pump, you would be interested in selling one to save another FF1 down under
Thierry
i see 2 shifter boots in the car 4wd???
i think the second boot is the shifter boot just sitting on the tunnel after been removed
Cheers Thierry
For sale ??? :-p
dont think so, he might need it if he ever fixes any of the ffi's he has
second last windscreen on on the planet... brother has a new one in his shed
Cheers Thierry
Leeroy, i ill be passing through your part of town end of april, just wandering if you will be free then
Thierry
Are we talking about the above gft that the son has
Thierry
Leeroy did you buy the GSR at seaford that was on ebay last week, I looked at it on the last day of bidding, was dissapointed that it didnt ave the original motor. The guy also said his son has a 1400 gft with he twin carb and 5 speed. I hadnt seen it but asked if i could have first refusal if he ever sells it.
Cheers Thierry
Maybe you might try to get it plastic welded and buid it up, file it down and drill the pin hole. Pain in the bum job
Cheers Thierry
wheels from the ea81 cars should fit, they have less back space, the H wheel were from that model from memory.
Cheers Thierry
ok 1400 heads on a 1600 block, love the porting for the weber manifold
Cheers Thierry
Air cooled motor doesnt sound promising
Cheers Thierry
I never heard of that engine and that period of time nothing subaru slipped by me, subaru only came back into rally in australia in 86 with the rx turbo, before that it was in the mid 70's with the rx1400 which i saw one when i bought my second ff1. But in saying it could of slipped pass me with out my knowing. SUB4 from NZ make 4 port heads for the ea81 for aircraft use.http://www.autoflight.co.nz/dominator/engine-1.jpg
Cheers Thierry
the dipstick tube should just press out and replace with another one no problems. that is if you want a dip stick
Thierry
i just noticed in the back ground an ea81 engine with twin down draft webers fitted about the heads like a VW
Cheers Thierry
did you know they are using you photo's on this web site
http://oolongo.com/subaru/1970-subaru-ff-1-1300-g-sports/
Cheers Thierry
I am thinking during manufacture that port might of cracked or broken into the water jaket, looking at the pics it is not far from the water jackets
Thierry
hmmm only number one cylinder has the air port and number one is leaking, the other end of that airport fitting is there any rad fluid connection close by, it could be leaking from there
Thierry
Kosta, i see a couple of threaded fitting above the exhaust ports, would it be possible there is a weep into the water jacket because of them, try blanking the exhaust flange and pressure test that fitting and see if it leeks into the water jacket
Cheers Thierry
I a puting it down to a crack in the head around the exhaust jacket/port. I cant think of any conection between the water and the exhaust like the inlet. so from what you are saying if that cylinder is at top dead centre both valves are closed and water is running out of the exhaust, and if the exhaust is open it floods the cylinder.does the water pour out or just drip from the exhaust
Cheers Thierry
Living out of a 360 van, i am assuming you are very verticaly challanged
Cheers Thierry
Any luck, Also the red GSR next to it, does it belong to one of our members, it looks familiar
Cheers Thierry
stumbled across another ff1 sports for sale in japan, he also has another one for sale more for parts but complete.
Cheers Thierry
Kosta. where the splices are , do they look factory or aftermarket. looks like a security device if aftermarket, if factory then it has got me stuffed, didnt have anything like that on my cars
Cheers Thierry
SUBARU STAR-ff1(1968-1971) EVERYTHING (photos,infos,etc)
in Historic Subaru Forum: 50's thru 70's
Posted
yes i have seen the front disc brakes, i had 2 cars with them, and at my brother's place, where he has the ff1's, there is a spare gearbox with the disc's still fitted.
Thierry
