TurboPropAirman
Posts posted by TurboPropAirman
Also just about every warning light under the sun went on, starting with low battery, ABS, and a very fast blinking "AT oil temp" light. Where would I find that alternator?
Hey, I have to jump start the car to get it running. Once running the voltage is between 8-10 with no accessories on. Can I remove the alternator to get it tested or does it have to be attached to the car?
I was reading the voltage right after I turned the car off, and it was with a multi-meter at the terminals.
I have a 99 Legacy GT, I was driving down the highway, and after about an hour of driving my speedometer and odometer plumeted straight down with no lag time. I later realized everytime I used my blinkers it would pop up and down with the blinkers. It did the same thing with the heater/ac, headlights, radio, and windshield wipers. The battery would not go past 10 Volts. I just recently had my alternator checked out (it was great) and all battery cables are tight and secure. Could it possibly be a relay, or is this a symptom of something much worse? How can I check a relay? (All fuses are good).
Thanks in advance for the help,
Chris
Don't do this, I tried this and blew all kind's of codes. Not to mention 2 MAF sensors, a coil pack, and some new wiring was required. When I took the state of the art "chip" apart I found it nothing more than a box with a wire and a resistor.
I cannot tug it at all it is stuck completley:banghead:
Hello, I have a 99 Legacy GT, and last night I opened the sunroof, and found it has no problem going backwards, however it will not go forward to close. The motor runs, but nothing happens. Any ideas, and if I have to remove the cassesett how would i go about doing that. Any help is greatly appreciated.
Thanks
Chris
Thanks for the insight I will give it a shot. What i mean when I say there is electricity in my grounds, is when I go to touch the ground {that is a known ground} I get a nice little shock. This is only when the amp is plugged in though. When I disconnect the amp nothing happens.
You can try, and cut out the metal, and extend it to the specs you need. I would just go with the 6.5's, and maybe get a small sub, and some tweeters.
I have a 99GT, and I am having both of those problems. I know it doesnt sound glamourous, but I pulled my dash out, took off the contact screws where the spedo screws into the contact mat, and added a bit of contact cleaner. Also check for anything that is loose, wires etc.. Mine had something barely hanging on, I taped that up, and put it back. Worked pretty well for me. As far as the transmission, well if you dont have a 5 spd, you may consider saving up for when it drops.
I am moving two amps in my car, I could swear I have everything hooked up correctly, and exactly the same way as I had it before I moved it, however when I turn the audio on, the speakers/subs hum. Furthurmore when I turn the engine on the speakers/subs wobble with the engine. I have grounded it in the exact same spot with the same wire, and my RCA/speaker wires are away from any power wires. One more thing that may help, I grounded it to three different spots to see if that was the problem when it did not solve it i put it back onto the original ground, and when I went to bolt the other grounds back up, I got a nice little shock?? Does anyone have any ideas on this.
One more note, I took the RCA cables out of the deck, and when I cover the black RCA cable with my hand, the hum goes away.
I noticed when the amp is plugged in, all the grounds in my car have electricity running through them.
Thanks in advance for any help.
All right, battery back up, but the same problem. Any other ideas would be great
Ok, my battery cannot keep up with what I am doing, I need to take a break for a bit to let it recharge, the audio eqpt. will automatically turn off when there is not enough power. I think this is the reason for the no sound from the subs.
In addition I hooked up the sub amp, and unhooked the four channel, it has power, but will not put anything to the subs??? all RCa's are fine, and the ant. is in.???
Everything is 4 gauge wire, I checked everything on the deck, and it is all fine there. Ground wires are all less than 2 ft. Monster cable RCa's. The one speaker hums, on all diffrent spots on amp. Cap is not hooked up at the moment to try and isolate the problem.
The amp is about 6 months old, I will try that.
It goes up when i turn the volume up, but the music is still over it. I took everything else off, grounds and all, and just had the one amp to the speakers running, and it still hums. If my amp was busted would it emit sound at all?
:-\ All grounded to diffrent spots, and I have a 1 farad cap. one amp is 1000 Watts, the other is 720 watts.
I have them grounded underneath the seats to a bolt. Its a good ground, I dont have them shilded with anything What is a ground loop, and how can i fix it?
Thanks, but the hum is still there regardless of power being applied to the subs or not.
Hello, I have a issue with my amps. I am hooking up 2 amplifiers, one to four speakers, and the other to 2 subwoofers. The speakers are hooked up in parrallel mode, and the subs are connected in series. The RCA cables are not running along the power line, however when I turn the audio on there is a low hum across everything speakers and subs. when I turn the sound up the hum is there and the speakers/subs work... I have no idea what is causing this hum, and cannot find any information as to what it is... PLEASE HELP
Thanks in advance!
I have searched for a while, and I have found some people saying to replace the ignitor coil. I want to do this, but can not find one compatible for my auto. Does anyone know anything that would work for higher performance. Also are there any other high performance tips. I have headers, catback, muffler, intake, and the underdrive pully. Any other advice would be great, thank you .
I have not pulled the TCU codes, is there anyone other than the dealer that can do it??? I dont want to pay an arm and a leg to have them do it.
My 99' Legacy has two problems I am unable to fix, and I was wondering if anyone could help.
My check engine light, and at oil temp light are flashing, when I put my car into drive or reverse its very hard to get going (I have to shift to neutral rev it up a bit, and shift back into drive) in order to get going. Sometimes during this time my engine will make a popping noise.
When I scanned it using the OBDII I recieved the codes
MAF/VAF
Circuit low input
--- I cleaned the old sensor (didnt work) replaced the sensor(no affect), and replaced the ECU (nothing). I think it has to do with the wires but I dont know what to look for on the multi-meter.
Cylinder 2
Misfire detected
--- I replaced the Ignitor coil, but I believe this is a secondary problem, and may be corrected with a new coil once the MAF sensor is fixed.
Any ideas on what to do or how to fix this problem will be greatly appreciated. Thanks.
Electrical Issue
Posted
I will try to get it tested, thank you. I hope this solves the problem.
