BoomerBoy
  1. Hey, y'all. This is my first post to this forum, though I've taken a lot of information and advice from many of you. Thank you so much for your help. I need help with a timing belt on my 1990 Legacy wagon 2.2 SOHC non-turbo. I bought a Haynes repair manual but it made the problem worse. The picture in the book shows notch marks on timing belt covers that line up with the cam shaft sprocket. But the timing belt covers on the car have no notches. It also states that there are 44 teeth from the center of the crank to the right hand cam and 40.5 teeth to the left hand cam sprocket. If this is correct, I can figure it out. If they're wrong on the picture and diagram they could be wrong on the number of teeth also. I need to know how to time up the car and would like to know the correct number of teeth to each cam. Thanks for any help you can offer. If you have anything to clear this up, I would appreciate it. I don't want to do all this work just to have to do it again. Thanks! BoomerBoy
