k88241
  1. I think the h7110as011 is the keyless entry module that may or may not have come with the car. The h7110fs201 is the security upgrade that does however just plug into the module. The security upgrade comes with a speaker and a shock sensor.
  2. I agree. I thought the 96- had the 60,000 interval and the 97+ had the 100,000 interval on the timing belts?
  3. Hello, If the antenna is stuck it could be it has a kink in it. I just replaced my antenna and you have to unscrew it from the outside. Look for two small holes in cap that the antenna goes down into. The holes are for a tool that unscrews that cap. The antenna will fall over and then power up the antenna and it should unroll the nylon thread coil and come out. Install the new one the same way. Be very carefull not to kink the new one. They cost about $50.00..ken
