johnusnsd
Posts posted by johnusnsd
Johnusnsd, I've just read eslwere that the brake line above the thank is stainless.
Are you absolutely sure that the break is located there?
You know....you are not the first person to say that to me.
The leak is above the gas tank....so, I believe the only brake line up there is the S/S one---and not a "rubber" brake hose.....BUT, I could be wrong.
When I step on the brake, there is a hissing sound and brake fluid sprays from above the gas tank.
I'm determined to re-route---but, unsure how to get at the end of the brake line by the wheel. How can I access that end to repair?
Thanks for everyone's help......v/r John
Hello
I have a 95 Legacy L Wagon with 140K miles, and the right rear brake line failed (ruptured). After getting the car lifted, I determined that the leak was up and behind the gas tank---and, it appears as though I can't get to the end of the brake line without dropping the gas tank (and, rear axle). Is this true---or, am I missing a different angle that I might be able to get at the brake line??? If I have to remove the gas tank, do I have to remove the rear axle as well??
Also, I have a good deal of rust on the bottom.....and, does anyone have any experience/suggestions regarding the removal/reinstallation of the gas tank/axle--and how the rust might impact the job.
I appreciate your assistance......Regards, John McGriff
Brake Line Replacement (95 Legacy)
Posted
