jburgess987
Everything posted by jburgess987
  1. according to haynes it is the engine that came with it and it looks to close to speck for a changeout.. i changed out alot of honda fuel injected and carborated systems and i think i would be able to tell if they had been changed.. does anyone know anthing about the other *exhaust lines* that run off the tank and run up to something next to the filler neck and could it cause a problem
  2. where is this screen your talking about... in the tank?.. the haynes manual talkes about a screen but i cant find it.. i put in a new pump and replaced all the line from the tank to the carb.. this sube has an inline pump and i get good pressure at the pump.. but if there is another screen i would really like to know where so i could check it
  3. i have an 87 gl wagon... i have replace the coil, wires, cap, button, fuel pump, filter, i am getting plenty of fuel pressure at the carb and at the pump.. it starts and idle wonderfully but when i pull out i get to 2nd (sometimes 3rd) gear and it stalls out.. after a restart it wont go at all.. after setting for 30 seconds or so it will pull out and run for another min.. also if i hold it at 3500 rpm it will stall as well after about 35 seconds but if i pour gas directly into the bowl it will remain running... im at a loss and i hope someone could point out some reason why this problem is occuring... PLEASE HELP... its my first subaru and if this is how they are then im going to stick with my honda:banghead:.. is it possible its not venting exhaust gasses properly?... hell i just dont know..
  4. i just purchased an 87 dl wagon... it would not start at all.. replaced plugs, wire, cap and button.. it fired right up.. pulled it out on the road.. went fine till it just fell flat.. replaced the fuel pump and filter and still nothing... idles ok but when i hold it at 3 grand or so it stalls out... had my wife hold it to 3500rpm.. as it started to stall i poured gas straight into the carb and it picked back up... im at a loss and am new to subaru.... any suggestions would be greatly appreciated:-\
