Known Indy Service Delaware/Philly
I have 98 OB. It's developed some strange noise(s) that at about 30-40 mph and over. I cannot tell if it is brakes or driveline or even wheel bearing related. It's an automatic and it seems to shift OK. I don't want to go the the local dealers. Any good independents in the area? Thanks!
Delaware Independent Shop for bkiwn HG
PeakMaster replied to PeakMaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYeah Concordville is where I bought it 10 years ago. Matt Slap in Newark is a possibility. But my thinking is to use a reliable independant repair shop. I am less inclined to go to a dealer for several reasons.
PeakMaster replied to PeakMaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks, but I am in Delaware near the PA border.
I have a blown head gasket on my 98 OB. I believe it is in the minor stages right now. Minimal loss of coolant, no coolant odor through the vents/heater. The car runs fine and maintains correct temp. as long as the rad. is kept full with coolant. I do however, smell exhaust distinctly in the expansion tank and in the radiator when I remove the cap. I want to get the job done by an independent shop. I simply do not trust the two closest dealers. Anybody have any suggestions for the Wilmington area or nearby in PA?:-\ Thanks!
'98 OBW Oil Pump Seal Help!!
PeakMaster replied to PeakMaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf you have a chance 99obw. I am taking it in early AM tomorrow and need to make some decisions based on priority. Which would you do in order of priority and assuming I keep the car through 100,000?
PeakMaster replied to PeakMaster's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks theotherskip and 99obw. 99obw, so how much am I looking at for that laundry list in terms of $$? Assuming 10% less then avg. dealer service cost.s? thanks!
I have an oil drip from the front of the engine on my '98 OBW with 64K on it. I bought it new and have routinely changed the oil every 3-4K. I've not had any other issues with this car. My research on this board and others indicates that this oil leak is either the oil pump 'O' ring , loose backing plate for the oil pump, or cam seal or valve cover gaskets. I tend to think it is the oil pump 'O' ring. My question: What else should I replace while my mechanic is doing the oil pump O ring? Thanks!
PeakMaster
