MATT NZ
  1. try idling the car up in the drive check that both the cooling fans are coming in when temp gets to normal operating temp on gauge if the gauge goes higher than normal and fans have not come in then check fan fuses and relays also all plugs and wiring if fans are operating get the radiator flow tested if there is a flow problem then renew the radiator core also check the water pump out plus when you fill these subarus up with water i find it is best to remove the highest hose from the top of the radiator and let it flow out the for a minute while still filling it and let engine idle up to normal operating temp before refiting the radiator cap and top up as necesary as these engines seem to air pocket alot also check that the engine is not pressurising ie blowing bubles in the cooling system
  2. Hi I understand that you can turn the boost cut out off on these legacys any chance anybody knows how to do that?
