Dr Farco
Posts posted by Dr Farco
  1. Thanx for the info coaster, I guess that rules out the module. I must have damaged the main light switch somehow when I was probing the relay sockets.maybe a short. I'm not getting a ground signal from the switch to pull in the relays. The lights work if I jump a ground to the connecter under the dash but no dash lights come on. Still can't figure out how a short could hurt the switch though. Except for this problem, this was the easiest remote starter install Ive done yet though. All of the necessary ignition, horn and lock wires are right there and easy to splice into. The Subaru light system is another story.
    DF
  2. Well, the auto starter she wanted works,as does the locks and the horn beeps but now I have no lights anywhere. All I can do is flash the high beams. The last thing I had to do was get the lights to flash. So as I was probing the headlight relay sockets for voltage, I saw a small arc to one of the terminals. The headlight switch seems like it's dead. It won't trigger any relays. I can hear the relays when I flash the highs however. Any Ideas?? The fuses for the lights next to the relays are good as are all the fuses in the kick panel fuse box. Are there any more fuses or breakers I can check? I saw a diode in the schematic but don't have a clue where it is or what it looks like.
    Thanx
    DF
  3. Boxers: My cams were the same way.
    I could turn one by hand and not the other. I could move it with a rag on the end with channel locks. I think it's just the way they are. There's always some coolant left in the block after pulling the motor. Are you using an engine stand?
    After I put mine on the stand, I rotated
    the engine on it's side to dump out the remaining oil and coolant before the cleaning began. I've put 1k miles on mine and so far so good.
    Good Luck.
    Dr. F
  4. Well, I was roaming around in "searchland" about dashboard lighting
    and as reported here, all of my 98OB's
    lights were toast. I replaced the HVAC and hazard lightbulbs. Now I found that the cruise and companion switches are supposed to be backlit also...back for more bulbs. As this thread originated in '01, has anyone noted if the Radio Shack bulbs last longer?
    Jest wunderin'!:confused:
    Dr F.
  5. As it was mentioned above, the earlier H/gaskets must have been inferior. I just had my Phase1 2.5 motor out for a top end rebuild due to a snapped timing belt tensioner mounting bolt. The temp gauge previously moved up and down like a windshield wiper. I looked at the old H/gaskets and didn't find any "breaks" in the metal, but the coating was missing and blotchy around the coolant openings. She's all back together now with the updated Subaru Gaskets and rebuilt heads and purrs like a kitten with a steady mid-range temp. indicated.
  6. I've used Mobil one for quite a few years, especially in engines that I've rebuilt. I have a Chevy Sprint 3-banger as a work
    car. This little devil works hard. When I had to pull the head a second time for a ring failure in one cylinder after 15,000 miles, it looked a clean as the day i put it together. The 98 O/B I just tore apart is filthy with varnish and dirt baked onto
    every thing. This car was run on dino oil no doubt during it's life. I think the Mobil one runs cleaner and dissipates heat a little better. The only catch with synthetics is that they are prone to find
    any weak seal and "weep" or leak. The stuff is slippery. When synthetics were first introduced years ago and packaged in cans, it wasn't uncommon to fine oil
    "weeping" from the can's bottom.
