Meandvls
  1. I just spoke to my subaru mechanic (independant) and he hasn't heard of anything like this before either. His first suggestion was same as several of you have suggested, check to see if the pump is working via a gauge in one of the test holes. He also mentioned to pull one of the cooling hoses and see if the pump is pumping ANY fluid at all. One other item he mentioned is a tube that goes from the torque converter through the axle housing to the tranny. If the tube didn't get in the right place or was damaged during the R & R of the trannys then no pressure would be going between the TC and the tranny....
  2. I appreciate the replies! I agree about the potential outside cause. My first reaction to the pinched cooler lines would be that it is not the problem. There has been no recent damage to the vehicle and during the tranny swap I did not see any damage to the lines. I will have to look at them closer where they go into the radiator. Yes, I used the same torque converter..:-\
  3. I can try the tranny cooler line as those lines are easy to access..but (now I don't know much about auto trannys) doesn't the tranny have a gear style pump INSIDE the tranny and if so...how could the pump be bad on both trannys? Also, remember, two trannys went bad back to back, the 2nd one after only about 3/4 mi after install...
  4. If a high pressure seal has popped, what would be the cause? Why would it happen to 2 trannys in a row especially the the 2nd one within 1 mile? As far as the CV's go, I'm pretty sure they are fine. I'm familiar with CV's going bad, although I've only had problems with CV's in the front... Blackbart; remember, after replacing the tranny, the car went approx 3/4 mi before it quit again. If it was a broken CV that was the original problem, it wouldn't of moved after replacing the trans.
  5. Oh man..I found this forum in an effort to try and figure out what the problem is with my 90 legacy awd wagon with auto tranny. Reading this post sounds real similar to my problem. My son was driving it and said he heard/felt a pop and then it would not do anything in forward or reverse. I was always suspect of the transmission so I decided to just replace it. I found a person parting out her subby sedan (93 I think) with 104k mi. and purchased the tranny for an awesome price of $130. I remove the old trans and installed the used one I had purchased. After putting new ATF and gear oil in to the proper levels, replacing engine oil and filter, and installing new spark plug wires (someone took one of the wires) I fired up the engine and warmed it up. I back out of the driveway and drove it about 1/2 mi down the road, turned around and head back home. About half way back I felt a pop and then nothing...no forward or reverse..same as with the tranny I just replaced. I pushed it back home and parked it. Any ideas on the problem? It is too much of a coincidence to have 2 trannys do the same thing.
