bumpingloyalekid
  1. car sterio noise deadning materials worked wonders for me, eg. dynamat. goes any where in the car you want it quite.
  2. w/ my 92, some times it will do the same thing, it will only engage/ disengage if... 1. clutch is in, 2. shifter stick is in neutral, and 3. car is rolling/ moving. it also dosent like it if the front tired are turned all the way to the right or the left. hope that helps.
  3. Hi, Ive come here for some information. i have a '92 loyale and the check enging light has been coming on and off during travle for about 4 months. eg. i turn on the car, and the light will some times be on, other times it will not be. and i drive for a bit then during travel it will turn off or on and will some times continue doing this every 5-25 mins or so. and recently i found two loose wiring harnesses inder the hood (near the wiper moter) and connected them, one was a green harness, and the other white. and then while driving after my light was on for roughly 5 mins or so, the light began to blink, once every second. my friend told me i connected the harnesses to diagnose the light. and i am wondering what the code is for the light blinking once a second. * note* when the light turns off/on i notice no change in performance in the car. thanks for any help!!!
