what parts do I need to tune my 96 legacy
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't intend on pulling the engine, my 96 OB has leaked oil considerably for a while and it is not big deal just to add the oil when needed and haven't had any real problems for a long time. If I was able to do the work myself and if I had a backup car, I don't, I might think about it, I have a feeling that the head gaskets may have been done already, I have none of the symptoms I have seen on any of the posts I have read, and the known problems on this model seemed to have already been resolved. Also please realize work costs me $60 an hour and so if I am leaking oil slightly I am not going to pay hundreds of dollars to fix it, all 4 of the ru's I have owned have leaked oil to some extent. I appreciate all of the advice greatly, but I don't have the luxury of being able to do the work myself or have a place to do it, though that would be nice. This car only cost me $1400 with the work already done, I have almost $2k into the car, I hope to drive it for a month or two then do the work when I have some more funds available, but I will buy the parts now. If and when the head gasket goes I will take care of it, I have watched the temp gauge like a hawk and will continue to do so, temp gauge has not really gotten up to the half way point yet and I the heater works very well. Thank you all very much, I welcome any and all response. Jay. Anyone know of a more reasonable solid mechanic in my area, I have used tomssvx a couple of times but he isn't doing work right now, LMK.
Ok I bought a 96 Legacy LSI wagon, ej2.5 with 93000 miles and after about 200 or so miles it has been an absolute pleasure to drive, the 6 disc changer has no cartridge and so I am going to put an Alpine deck in with built in bluetooth. Anyway I want to do the preventative maintenance like we usually do (my wife and I) so what parts do I need besides these. Oh it was leaking oil badly when I bought it replaced the valve cover gaskets, new tires, back brakes and rotors and an inspection, and it seems to have subsided, still smell oil a little when I get out of the car but it has not been cleaned since the gaskets were put in. timing belt water pump oil pump o ring water pump wire set plugs idler fuel filter air filter do I need a tensioner?? It is an automatic was owned by an older woman and she did not drive it too much, don't have the service records though, also the gas fill pipe must have given out so they replaced it, will post pics later, however the door covering the gas cap and pipe area will not close, there is not latch on the car side of things just a hole, any ideas? Also I will be having a local mechanic do all the labor as I really don't do very much on cars, houses yes, cars not really. Thank you to everyone for all your help, hope to hear from you soon
Bought a new Soob, could someone run a carfax please
Hi, I just bought a 1996 Subaru Legacy LSI wagon for $1420, it only has 93000 miles but I am a little concerned because it has the 2.5l engine instead of the 2.2l. It needs some tires, back brakes and some seals, it is leaking oil pretty good, but my mechanic had it on the lift and said it looks like an excellent buy. Here is the vin 4S3BK6650T7305731 Thanks a bunch for any help anyone could give, have a great night. Jay.
Going to look at a 96 Legacy L wagon on Saturday
Hi, Haven't posted in some time, I am going to look at a 1996 Subie Legacy L wagon with 103k, automatic, supposed to come with 2 sets of tires, snow tires and a set of all season tires, also comes with chains, apparently this guy was from greece and was nervous about driving in our Philly weather, shrug. Anyway he wants $2k and he is going to let me take it to my mechanic who I am sure will go over it pretty well, he has done this a few times for my over the years. So I know to to do the slow figure 8's to check for torque bind, he told me it has a small oil leak, and the abs light comes on and goes off now and then, so what should I be checking for or have my mechanic look for, any help would be appreciated. BTW my wife's 96 impreza outback has 187k on it and is still running strong, although I bought that car in 2005 and so this car makes me a bit more nervous to be buying a 14-15 year old car as a daily driver. Thanks, Jay.
96 impreza outback Brake lights will not go off!!!!!
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIt turned out that the first shop put the wrong switch in, the second shop put the wrong subaru switch in, called in the info to subaru with the vin and found the correct switch. No mo problems . Jay
Ok I have a 96 impreza outback that the brake lights will not go off, no it is not the parking lights switch, the actual brake lights stay on all the time. I took it to a shop and he replaced a switch by the fuse box, 1 week later problems returns, take the car back replace switch again, now it is back again. I have done a little research and have found it may be one of 2 things, emergency brake switch or low brake fluid. Filled the brake fluid, problem is still occuring, so I could really use some help here fellows, my wife would like to use her car and so if you could figure this out for me I would be very appreciative. Jay.
CV boot hell
Jaysz replied to 1995SubaruImpreza's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXUmmm not sure if you guys are aware of this but... http://www.amazon.com/GCK-Industrial-SB8009-Front-Wheel/dp/B000FF5EK6/ref=sr_1_3/103-5443969-7569439?ie=UTF8&s=automotive&qid=1191934136&sr=8-3
Need a 96 obw power steering pump
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTried to pm you, your mailbox is full, what is the history on the pump and do you have the reservoir as well? Thanks, Jay.
Well I took my car today and had 2 new GCK axles installed by guy from the svx-forum, and he installed them and they are fine. I have a problem with my power steering unit leaking and he asked if could come here to source a used one that is good or was a good pull. Well if anyone can help let me know, thanks. Jay. Any general suggestions would be welcome as well, 96 impreza outback 5spd, 150k.
Clutch replacement - newbie job or no?
Jaysz replied to eryque's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI paid $600 for my 96 impreza outback 5 speed, if that helps at all.
93 Legacy L problems
Ok so I bought a 93 Legacy l in January, around march 30th I find out the title was never processed and so after March 30th I could not drive it until the now, later this week I should receive the title and all. Find out the car was supposed to be junked because of rusting of the rear axel, she gave this car to so and so and he instead of junking it repaired it somewhat and sold it to me. I noticed while I drove it, about 4k miles or so, until my plate expired that it would click on the right rear wheel now and then, sometimes it would click repeatedly, sometimes just a few times. The engine and trans are in excellent shape, I have had the car at 90-100 without problems as far as the engine and trans but she wiggles or floats. The sway bar is almost brand new oem. There is a good amount of rust on the undercarriage but it hasn't eaten holes in the underside or anything close, a bracket that holds a cable has broken off but it stays in place. Almost forgot 121k, automatic. Think I can get this car roadworthy again?? Jay
96 impreza outback problems
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk well I changed the wireset and the problem stopped, today we replaced the spark plugs with NGK V-Power copper core plugs, it runs a little better after the new plugs. 1 plug I am assuming cylinder #3(see 1st post) was burned a little, had some blackness on the white part of the plug as well as the tip, the other 3 where a good bit better looking. The CEL is still on, will it go off in a few days or will I have to have someone turn it off with an OBDII unit?? Thanks for all the help folks, I will be back with some more questions shortly, I have axle problems with my 93 legacy L, but that's for another day. Jay. CEL went off today and has stayed off.
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXCar did not have one when I purchased, I will just ask the guy at the parts counter, thanks though . Jay.
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk so what kind of plugs should I buy? Last time I bought the NGK Iridium as I previously stated, those cost $7 each is it worth it or should I go with a cheaper plug? Thanks.
Jaysz replied to Jaysz's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOrdered a set of wires from Reedman-Toll Subaru in Langhorn, will be in tomorrow price is $38.92. Am I supposed to use di-electric grease when installing these, someone told me I should. Jay.
Jaysz
