What transmissions will fit my Outback?
I have a 96 Legacy Outback Automatic with the 2.5 engine. I need to find a used transmission. How can I tell which transmissions will work in my car, there are so many different numbers. Which models and years to search for? Is there A list posted anywhere? I was going to post my transmission number but dont have it with me now. The reason you ask! Well!! It seems when I reinstalled the engine the torque converter must not have been seated in all the way, and from reading in the forums sounds like I broke the pump because it lasted 2 days before it started slipping and then 2 day later quit working.
oil in coolant can this be a head gasket?
mechdoug replied to mechdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for everyone's input! Looks like I'll be pulling the motor and adding a gasket set. What do you suggest flushing the cooling system with? Where is the best place to buy a gasket set?
mechdoug replied to mechdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXDoes the head gasket explain the oil too! Maybe the gasket is damaged where the oil passages are to the head?
mechdoug replied to mechdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWifes car. Said she got to the corner 1 mile away from home and engine sputtered or back firedand the check engine light came on, so she drove it back home and parked it. I came home read the codes (2) cyl 1 missfire. Cleared codes started engine seemed OK. Next day she drove to work 15 miles everything OK, drove home to drop off a kid then headed out again 12 miles or so got to stop sign smoke coming from under the hood. Checked under hood left side of engine compartment and wheel all wet. She drove 1 mile to my dads and called to say she had coolant all over under the hood and drivers tire. I filled the radiator and overflow tank and found dark grey stuff floating to the top of the coolant. Overflow hose fit very loose to the radiator.
oil in coolant can this be a head gasket? or is it worse? 96 legacy outback 2.5 auto 165000 miles
help 97 Outback swapout 2.5 for 98 2.2
mechdoug replied to mechdoug's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have all the parts from the 97 2.5 car. The 98 2.2 engine will not come with a/c compressor,alternator,steering pump. Unless I spend an extra $200 to keep these with the 2.2 engine.It will have the exhaust manifold Y-pipe with it. Both are Manual Trans.
Will the powersteering pump,Alt,a/c compressor from a 97 2.5 fit on a 98 2.2 engine?
mechdoug
