Everything posted by autos_by_jake
OBD I codes 51 and 52 Info needed.
That got it! Thanks again for the info. I clipped the B48/20 ground lead. That took care of the automatic park code. then I fashioned a micro switch to the clutch pedal for the 51 code. Now when the clutch pedal is at rest there is a complete circuit to ground. When you engage the clutch the circuit is broken and all is right with the world. Connecting the green connectors shows steady "1"s. Kudos to you sir.
That's some teriffic information! I suspect I'll be able to resolve both of them with this stuff. Thanks a ton! The van just came back to me after a 3 week trip to Arkansas. I've only got a few days to work on it though. It's going to Colorado this Friday... Ah what fun.
Required VW vintage for Soobie swap
You can convert any van you want. As it's been stated, anything with water in it already will be a great deal easier (and cheaper!). Aircooled vans take a fair bit of fabbing to make the cooling system work. I'm just finishing up an '87 Westy right now with an EJ22. The interest from my Vanagon owning customers (and random outsiders) has been almost overwhelming. A cust. just gave me a diesel '82 and I'm torn between putting a TDI motor in it or finding a WRX motor to shoehorn into it. I know that whatever powerplant makes it into the back of this thing, I'm gonna turn it into a pick-up truck.
So here's the skinny. I've swapped a '90 EJ22 automatic engine into the rump of an '87 VW Vanagon. I know having just read that sentence you're probably thinking "post this in the Vanaru section"... Well, this thing runs great, and I'm just trying to get some more info on how the switches functioned when they were in their original enviornment so I know what I need to replicate to stop the last of my check engine codes. I understand that 51 is the "inhibitor switch". I've done some research and found that the switch connects between the ECU and ground. What is the expected state of this switch? Meaning, when the ECU looks at this switch does it want to see a clear path to ground at startup and then no ground before the vehicle begins to move, or does it want to see nothing, then a ground just before moving? I have the same question about the Parking switch ( code 52). This switch also attaches to both the ECU and ground. For what it's worth I've gutted the reed switch and magnet from the Subaru instrument cluster and created my own VSS so the engine does in fact know when the vehicle is in motion. Hence no code 33. I've searched over 13 pages of info without finding the specific info I am looking for. Any help would be greatly appreciated. thanks in advance, Jake
Air suspension goes pffft!
autos_by_jake replied to bivywack's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXToo bad I didn't know about this a week ago. I just crushed an entire '90 leg. wagon. The susp. was in prime shape.
