Everything posted by Groundworx
RHD 91 Legacy Auto to 5-speed Man swap
Groundworx replied to bigmicah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhere did you get one at?
Groundworx replied to bigmicah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI haven't seen many rhd's w/manual tranny's. It would make sense to me that the shift pattern would be flipped. Sorry I don't have your knowledge on this matter.:-\
Legacy cooling question
Groundworx replied to Groundworx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOn my 93, neither fan was coming on. One of the fans on it is larger than the other. I got that fixed. Both fans on the 98 are the same size. One was coming on and the other wasn't. I wired the 2nd one up direct and now the other isn't coming on. I haven't driven much since, but I believe that fixed it. It would make sense to me that they both should come on.
Groundworx replied to bigmicah's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have 2 rhd Legacy's. Both are autos though. I would think the shift pattern would be backwards. If it does use a cable, the cable may need to be modified for the proper length, but I wouldn't think it would very hard to do a swap. You would think most everything would bolt right on. You may have to get some parts from overseas, but I wouldn't think you would need much
Groundworx replied to Groundworx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPump is fine. I have washed out the radiator. On a 98, are both fans supposed to come on at the same time?
Groundworx replied to Groundworx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI know about the stat. You can get by with an aftermarket one if you drill a hole in the side where that little thing is. It has been bled. The fans were not coming on. The wiring is fine so I guess it needs that sensor. I have driven it the past couple of days with the fan hooked up to a toggle switch and it has been fine. Where is that sensor located? Now, my 98 is overheating as well. I believe there is a leak and I will be investigating that tonight. One of the fans is coming on. Are both supposed to come on? I replaced the cap yesterday and pulled the stat completely out and it is still getting hot. It seems to be circulating good. I hope the pump is ok. I hate replacing those.
Groundworx replied to Groundworx's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI was driving the 93 today and it is getting way hotter than it should. I found out though that my fans are not coming on at all. I checked the fuses and they aren't blown. I don't know if there is a sensor that has went bad. I wired them to a toggle switch and I will see if that fixes it. I pulled the stat on it this weekend and it still got hot. The water is circulating good and I have no leaks. I don't think I have an air pocket in it. I am thinking of getting a new radiator pretty soon, but I need to find out what the problem is. I was wondering if someone made something that made the fans come on sooner. I know there are a couple of companies tha make them for the LT1 GM cars.
I have a 93 and a 98 Legacy. Both non turbos. It seems every summer, I seem to have cooling problems with both. Nothing really serious, but they both seem to get a little hotter than normal. Does anyone make something that fixes this? Mabey something that makes the fans come on sooner?
